Old 06-21-2017, 05:32 PM   #19
Liked 17,794 Times in 1,614 Posts
Default Re: "Live" from Norwalk 2017
Hello everyone, I got here a few hours ago and it was smooth sailing. It looks like the parking crew did a great job getting everyone parked. No lines, just pulled right into the track.
There was a small line at the credential trailer, but the wait was not to bad. They did make a change as far as getting a restricted area access sticker for your racer credential. They no longer give you the chrome sticker for restricted area access if you are a driver. They said you are in the car so you don't need it.
The question I had was, what happens when you are outside your car in the lanes, which are restricted. They did not have an answer. If you are a crew member you can get the access sticker. If you are a driver, you will have to get on another drivers credentials to get the pass. If you don't have a friend that has a crew pass left you are out of luck.
I am not sure why or what was the reason for this. Many drivers crew for other racers in other classes. All drivers sign the waiver for the restricted areas. I'm sure this is a mistake.
I took a few batches of photos today. The weather is nice and we are hoping for a good week. The weather forecast is all over the place and is in constant change, lets hope for the best.
ID:	40530   Click image for larger version
ID:	40531   Click image for larger version
ID:	40533   Click image for larger version
ID:	40534   Click image for larger version
ID:	40536   Click image for larger version
ID:	40537   Click image for larger version
