Old 05-13-2017, 12:08 PM   #261
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
From my experience , most of these high speed driveline vibrations are shaft related. Usually from not having a 3-4 degree balance between the two angles.
Did you say you still had the mufflers on it?
I would guess it was still almost 90 degrees at 8 pm, and ODA approaching 4000'.
Already been over 100 in the valley.
Yes, mufflers still on. It was warm but not really hot. I'll be double-checking some things a little later today.
Dave Muller is offline   Reply With Quote
Old 05-13-2017, 03:10 PM   #262
Dave Muller
I don't really see anything wrong with the driveshaft. It pulls back 1 1/16" from fully inserted into the trans. And it's a 3 1/2" shaft. Maybe there's just a problem with the balance? There is room to go even larger on the shaft.
Here's how it looks installed.
There's a little over a half inch of output shaft protruding from the transmission.
Old 05-13-2017, 04:18 PM   #263
Liked 5,139 Times in 1,962 Posts
That's plenty big for the shaft.You could use a stock driveshaft in that car.
If you've got time, I'd take it to Phx rack and axle , north of the airport.
See Bernie. Have him check runout and balance. He's the best.
Maybe it's the camera angle, but I don't see any down angle on the U-joint.
Old 05-13-2017, 05:45 PM   #264
Dave Muller
You can't really tell from that picture.
I just got the slicks dynamically balanced, and the prior job was done with clip-on weights on the inside only. This time they're stuck on in the middle of the wheel.
I have three days, I'll check into that Mark, thanks for the tip.
Old 05-13-2017, 10:12 PM   #265
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
We've always bubble balanced our tires ourselves and use stick on weights in the inside (duct tape) for additional security. Never had a problem. The two times we experienced vibrations at speed it was the driveshaft. Have it rebalanced by a shop that can spin it fast enough. I took one to a local shop and had it balanced and still had a vibration. Mark Williams told.md you have to find a shop that can turn it 10k I believe is the number they gave me. I did that and no problem.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-13-2017, 11:40 PM   #266
Ed, Usually not a problem. They bubble balance at national meets, of course.
But , if you can get the wheel and tire under the safety hood, it's good way to check for wheel runout or a defective or improperly mounted tire.
Old 05-14-2017, 11:02 PM   #267
Dave Muller
Here's a couple of pictures from my test session, courtesy of Jerry Hutchcroft, of Roddin' & Racin' magazine.
Old 05-15-2017, 11:53 AM   #268
Ed Carpenter
Great looking car!
Ed Carpenter
Old 05-15-2017, 08:57 PM   #269
Dave Muller
I took the driveshaft in to Bernie today and he found .019" of run-out. He straightened and rebalanced it while I waited; didn't even use up my whole lunch hour. I'm very optimistic at this point.
I also hope to have enough ballast in to remove the headers. Oops--I meant remove the mufflers. My fingers type faster than my brain thinks sometimes!
Old 05-16-2017, 11:54 AM   #270
Dave, You found that rulebook section on ballast for Stock Elim.?
