Liked 653 Times in 89 Posts
Why is it so hard to look up at the scoreboards before you stage your car to check your dial? Take responsibility for yourself end of story. Typical liberal America now, blame somebody else because you did not check the board to make sure it was correct yourself.
Charley Downing 3548 STK |
#2 | |
Liked 535 Times in 86 Posts
Jim is not complaining & neither am I, just making a point. NHRA doesn't care. What if Jim had won the that race?
Chuck Beach 3340 STK Last edited by Chuck Beach; 05-11-2017 at 02:08 PM. |
Liked 483 Times in 92 Posts
Does anybody remember what happened at the Fall Charlotte race last year?
First Round, Stock L: Jeff Warren Dial 10.38 R: John Leach Dial 10.52 The tree dropped as it should, but when they got to the finish line, the system had this on the screen. L: John Leach, Dial 11.40 R: Jeff Warren, Dial 10.52 It had swapped the lanes info as well as switched a dial-in on the left lane to read index. They did re-run this pair. Weird occurrence, until the same thing happened at a bracket race near me a couple months prior to this. Compulink will always be susceptible to glitches, so even if the scoreboards read correctly, the system may throw you a curveball. Everyone pay attention to the boards and the timeslip. This round is still on All Access on the Fall Charlotte coverage, under Saturday, around the 46-47 minute mark.
Austin Williams 3 SG 464Q STK SC |
Liked 317 Times in 103 Posts
Any racer out there who has had something go array with the dial in, has always checked their dial in before they have staged after that incident. If they haven't had it happen to them yet, it will. Then they will check the dial in after that.
Like it has been said on here before, "it is the drivers responsibility".Personally, I can't believe Jim let this happen for as long as he has been racing. Then, maybe, he has never had a dial in problem before. If that is the case, he won't do it again. As a side note, if you dial in improperly, your fault, no rerun and you are DQ'd, no matter what the run resulted in. Just the way it is. Lets not make this more complicated. Ron Ortiz U/SA dialed and ready to go.
Ron Ortiz 2102 STK |
Liked 2 Times in 1 Post
Looks like they need to change the warning sounds to differentiate between an illegal dial-in and entering the next pair. Or put up a warning message and not even allow the dial-in to be entered and flash the whole screen.
Liked 8,249 Times in 1,542 Posts
First of all, I have the UTMOST respect for the Golddigger...Jim Boudreau..Every racer MUST check their dial in before they stage because....with the NEW NHRA this will happen again and again .....
Liked 7,925 Times in 1,760 Posts
I think that the person who was entering the dials in Atlanta just got in trouble in his NEW job in Hawaii!
