02-04-2017, 07:46 PM | #11 |
Liked 311 Times in 81 Posts
Re: 69 Camaro B/S
Back at it.... finished cleaning the fire wall and 1 coat of por down, waiting on the correct color for the door jams and upper cowl. I'll tone down the shine with a few coats of satin.
We planned on notching the cross member for oil pan removal. I really like how Tim had his done for the 67 so I had my guy copy it with added Jack point and tow hook.Came out great!!!! Hope to have it mounted later this week. |
02-04-2017, 10:13 PM | #12 |
Liked 2 Times in 2 Posts
Re: 69 Camaro B/S
Nice looking build on your B/S Camaro!
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
02-13-2017, 08:56 PM | #13 |
Re: 69 Camaro B/S
02-14-2017, 01:13 AM | #14 |
Liked 181 Times in 111 Posts
Re: 69 Camaro B/S
Very nice work!
D |
04-01-2017, 02:35 PM | #15 |
Re: 69 Camaro B/S
It's been a long battle but the steering is finally coming together.
The first problem I had was with the tie rods.... I planned on using the Baer tracker kit but had a problem with the inner tie rods being to long. After a lot if back and forth I decided to build inners. I'm happy how they came out. I also ran into a issue with the column being compressed leaving a 1/2" gap between the rag joint and flange. We couldn't figure out why since there was no evidence of a front end collision. I think this happened from the body bushings being so bad. I put a strap around the flange and tried to pull it out with no luck. I was able to slide the column down and everything fits great with no bind. Gonna tackle the headliner this weekend then she's ready for the chassis shop. |
04-03-2017, 11:35 AM | #16 |
Liked 233 Times in 124 Posts
Re: 69 Camaro B/S
04-03-2017, 08:10 PM | #17 | |
Re: 69 Camaro B/S
Initial thinking was it would be easier to install without the cage. Since I'm doing it myself worse case it's $70 if it gets damaged....I really don't want to pull the rear glass and plan on running a 12 point so the extra bars will make the back tough. I'll cover it with cardboard and the guy doing the cage said he will use a welding blanket. |
04-03-2017, 08:21 PM | #18 |
Liked 322 Times in 118 Posts
Re: 69 Camaro B/S
Did your POR on the firewall also or just the frame? |
04-03-2017, 09:28 PM | #19 |
Liked 154 Times in 68 Posts
Re: 69 Camaro B/S
Are those heim style tie rod kits legal in stock now?
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
04-03-2017, 09:30 PM | #20 | |
Re: 69 Camaro B/S
