Old 03-20-2017, 04:54 PM   #1
bigfoot584
Default Re: Racing Software Group Buy
Originally Posted by Tom Broome View Post
I am using a Windows 7 machine.
Downloaded the file referenced in the post above. What do I have to lose at this point, Right?
Looked for extracted folder "VB6_Old_Tools", that folder does not exist in the file that was downloaded.
You tell me not to panic, yet the fixes do not work. The original download does not work. But the $99 non refundable charge went through and worked THE FIRST TIME.
You admit that"guys have this same problem". How many actually worked? That's $99, times the 250 people who decided to participate in this "Group Buy", pretty good action for a country boy like me.
"Don't Panic" Really?
My first question did you extract or unzip that
file, if not make a folder name it junk and copy
the file into it, then extract or unzip it and you
will see 4 files appear one will be setup.exe
double click that one and it should be done.
If all is well you can delete the junk folder if
you'd like then.
Hope this helps, He could have done better
here I believe.
bigfoot584 is offline   Reply With Quote
Old 03-21-2017, 09:23 AM   #2
Tom Broome
Liked 88 Times in 43 Posts
you'd like then.
here I believe.
(1) Download this file - http://racingsupport.com/VB6_Old_Tools.zip
I downloaded the file, save to desktop, unzipped the file.
2) Extract the download zip file (Plenty of free apps online to do this if needed)
Searched through all of the files in the download.
(3) Find extracted folder “VB6_Old_Tools” and double click to open
This folder is not contained in the file, there is a folder with some portions of the name provided.
I opened it and.....
(4) Double click “setup(.exe)” file to run fix
There is no exe file in the folder in the download.
Don't panic guys had same problem this fix it.
The files should all be in your c:\windows\system32 folder then.
This is supposed to be a group buy for racers, not software designers.
Make it user friendly.
So....the software does not work and we cannot get our money refunded. Apparently I'm not the only one affected by this issue.
Was the software intentionally faulty?
I'm pretty sure there is a legal term to describe this condition.
Tom Broome is offline   Reply With Quote
