Old 03-03-2017, 09:11 AM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Metric 200 Locking Dipstick
I use this Lokar: http://www.jegs.com/i/Lokar/625/1211344/10002/-1
Disconnecting the flexible dipstick tube from the trans and popping in the sealing plug makes changing transmissions a lot easier. The firewall mount eliminates one more juggling act compared to a trans bolt mounted unit, especially when you have limited firewall space. -Al
"That'll never work....."
Old 03-03-2017, 09:38 AM   #2
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Lokar. For the top mount I made a bracket with two holes and bolts thru the holes and the heads welded to it, mounted it to the firewall from the inside and pop riveted it from the out side with one rivet. Now you have two studs sticking out and you can fasten the top. Makes it easy to loosen the top when dropping the trans and then you have easier access to remove the tube and put in the plug, and same when installing the trans.
Mike Moller
NHRA 203 Q-R-T/SA
