Old 02-06-2017, 12:41 PM   #1
hutt1
Default Re: Not exactly a dime rocket but close.
We are doing good with it.. We have our new turbo back from Charlie after his wreck and long hospital stay.. The turbo we ran last year was a high mile mile turbo out of a junkyard. So I'm interested to see the difference. Hoping to spend a day on the chassis dyno this spring also...once its back together. I did a lot of the same stuff you did like manual rack, bump steer, adjustable struts, caster camber plates and so on..Keep us informed on your progress.
Scott
hutt1 is offline   Reply With Quote
Old 02-12-2017, 08:51 PM   #2
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
[QUOTE=hutt1;526100]We are doing good with it.. We have our new turbo back from Charlie after his wreck and long hospital stay.. The turbo we ran last year was a high mile mile turbo out of a junkyard. So I'm interested to see the difference. Hoping to spend a day on the chassis dyno this spring also...once its back together. I did a lot of the same stuff you did like manual rack, bump steer, adjustable struts, caster camber plates and so on..Keep us informed on your progress.
Will do scott! as soon as I make any changes I will update this page, I too am interested in seeing the gains if any in one of charlies turbos,i am also using a JY turbo that seems to be fine for now,keep me posted on your dyno dat! thanks......fred
fred goodwin is offline   Reply With Quote
Old 09-05-2019, 09:41 PM   #3
fred goodwin
well after a break in the racing program because I moved to Kentucky! I finally got to run the tbird again,this time with a stick and it didn't run to bad! 13.05 @ 102 in Q/S !
still lots of little things I want to try over the winter and im looking forward to next season!
here is a video thanks to alan mackin!
Old 02-07-2020, 05:56 PM   #4
stk1219
Liked 5 Times in 1 Post
This is a older post by I have a chance to pick up a 87 T-Bird Turbo coupe. Was thinking of slow build to stocker by starting as bracket car and remove as much weight as possible. The car has 100K with auto trans. What would be first few things to do, ie tires/ wheels (what sizes). Does the rearend need to be swapped if so to what, gearing, ect. I'm thinking of dime rocket budget with junk yard and swap meet finds. Just looking to run little under index and having fun.
stk1219 is offline   Reply With Quote
Old 05-19-2020, 05:50 PM   #5
Frank Castros
Liked 2,727 Times in 961 Posts
Check this out.
https://bringatrailer.com/listing/19...ountry-squire/
Old 05-19-2020, 06:11 PM   #6
Frank Castros
Dwight what class would this beast run?
I wouldn't even paint it!
Old 05-19-2020, 06:27 PM   #7
Billy Nees
Liked 7,745 Times in 1,740 Posts
G/H/I Frank, I'm sure that you're kidding. That car is way too rare to make into a Stocker! Cool car though!
Billy Nees 1188 STK, SS
Old 05-20-2020, 12:09 AM   #8
Liked 5,124 Times in 1,953 Posts
Talking Re: Not exactly a dime rocket but close.
LOL No "patina-ed" cars in Stock, please
