Old 01-04-2008, 11:00 AM   #1
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Radial Wabble Problem
Put some snubbers on the front end so the front end can only go down so far. You will be amazed at how much that will help.
Greg
Old 01-15-2009, 11:45 AM   #2
Roger K Fain
In your description of the problem you left out many of the possible contributing factors. What is happening to the vehicle is the suspension is unloading upon deceleration and finding weak points in the structure or geometry. The radials are a major contributor to the reaction of the suspension, but not the initiater. If you have a four-link suspension, you may have a problem with your wishbone flexing, bending, or just loose in the mounting.Check to ensure that all connecting points of bars are sufficiently secured and not allowed to "wobble", thus keeping the car in a straight line until the suspension collects itself.
Additionally, make sure the front suspension reacts equally in separation and compression and is totally fluid in movement.
Roger K Fain is offline   Reply With Quote
Old 01-04-2008, 02:04 PM   #3
mike withers
Liked 3 Times in 1 Post
I had heard the radials should only be used on automatic cars but I just had to try them on my stick car. Wow! the tire shake was incredible I thought I was in a fuel car. It didn't settle down until I put it into third gear.The announcer at Norwalk said it looked like basketball going down the track More air pressure did not help Two passes were enough for me to see the light. They just do not have enough sidewall. As for your problems I have observed wobbles similar to what you are experiencung on My buddies sperstock hemi car. I do know he has double adjustable shocks front and rear.
mike withers is offline   Reply With Quote
Old 01-04-2008, 03:00 PM   #4
tim worner
Liked 126 Times in 20 Posts
We have M/T radials on all 3 of our cars and have no problems. For sure a radial tire will bring out any problems in your suspension and also the track. The only time my car tends to roll or pitch is on a uneven surface. I would recommend no less than 16lbs air pressure. Also make sure both tires are the same roll out and the correct direction.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 01-04-2008, 08:48 PM   #5
mr305
Liked 2 Times in 1 Post
Send a message via Yahoo to mr305
Talking Re: Radial Wabble Problem
Thanks for all your post guys. Ya'll are teaching me here since im a rookie at this kinda stuff. i do know the circumfrance of the tires are the same to and 1/8 inch. and they are all heading the right direction. i just dont wanna crunch up there car or anyone elses for that matter. i just wanna get it fixed. Thanks again for all your guys help. and if you have any other suggestions please don't hesitate there is still alot of winter left and i get bored pretty easy lol. thanks
aaron disinger
327y
gt/ha
mr305 is offline   Reply With Quote
Old 01-14-2009, 01:37 PM   #6
Joe Hertline
Liked 3 Times in 2 Posts
along with the front snubbers, if you're having problems with wobble at the top end in the shutdown make sure the front snubbers hit at the same time...ie push down on the front of the car and be sure that one side does not go down farther than the other. When you're slowing down, the front end usually bottoms down and uneveness can cause oscillation that is magnified in the radials. Might be part of the problem, but shocks are likely to contribute too. Good luck finding the cause.
Joe Hertline 1318 SS/FA
Joe Hertline is offline   Reply With Quote
Old 01-14-2009, 04:01 PM   #7
Dick Kirkpatrick
Sounds to me like you don't have any (or not enough) toe in.
This will also scrub off mph
Dick Kirkpatrick 3033 SS
Dick Kirkpatrick is offline   Reply With Quote
