Old 02-02-2017, 06:42 PM   #4
FED 387
Liked 333 Times in 180 Posts
Default Re: License Question
Remember also to tell the track about your licensing runs they generally are are very accommodating and will stop the action so that you are the only car on the track at the time you will need to get the track mgr to sign your license runs as well as 2 other racers that have a license the same or greater than yours meaning a Pro stock or a super comp can be witnesses. also you can make your runs on a 1/8 mile track. What the witnesses are looking for is your abilities to handle the car your full runs should be representative for your class like in the 80-90% ET range or say 8.50-8.75 on a 8.30/or so but definitely not say a 10.00 run on an 850. If you have driven stockers befo you will do fine just concentrate on what you are doing. Also not knowing your age check into wether you need a physical and if you are over 55 you might need an EKG also. FED 387
