Chrysler 904 trans for Chevy has chevy bolt pattern built by Allison A&A
Transmission aluminum drums internally modified case has reverse pattern valve body with trans brake with clean neutral at rear. comes with PTC 7 " converter must use 1/4 " motor plate & small flywheel 157 tooth. 5 1/4 mile runs since freshened. Deep aluminum pan. $2200.00 plus shipping.2.45 - 1.45 - 1 gear ratio Have 2.75 gear set that goes with trans. Also have Turbo-Action air operated shifter modified by ACD for above trans $400. more info 256-310-1745
Jerry Harris 2111 SS Last edited by jerry harris; 01-21-2017 at 06:54 PM. Reason: Left out some info |
