Old 12-14-2016, 01:18 AM   #1
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
Default Re: Manual trans only?
Originally Posted by SStockDart View Post
Sorry for getting off track here. You are right and I am wrong...never too old to learn something. In 1964, Thunderbolt produced 51 automatics and 49 4 speeds.
No prob sir!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 12-14-2016, 12:56 PM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Manual trans only?
Ford, once calling itself the Ford Family of Fine Cars, had a problem of parts interchangeability among engine families, trans groupings, and the like that knew no bounds, going all the way back to the 1950's.About the only fairly standardized unit was the 9 inch rear end, going all the way back.You Fordophiles would know way more about all this that I do, but within engine families, there are enough variations to drive you nuts. Doing an engine for my brother's 64 Falcon Sprint was a disaster. He made the classic mistake of putting an open plenum hi rise intake on his 260 with a big Holley, which was some improvement over the 2 barrel, but that carb was way too big for that motor. Add to that, a screw dropped out of the throttle body to the float bowl, and the engine ate the screw, some pistons, and cracked a cylinder wall. We decided to rebuild the motor, so out it came. He located a 289 block, missing one main cap, pretty cheaply. No cracks, it cleaned up at .030", but we needed to find a main cap and get it line bored and honed. More money. The cheap block wasn't so cheap. We used the 260 crank and rods, flat top 289 pistons, and had that balanced. I don't know what all had to come off the pistons, but I don't remember that being a problem. I assembled the short block, he got some 289 heads, and a cam,lifter and whatever else kit. I did the heads at school, took them home, we bolted the whole thing together and I installed the engine. When I put the steel stamped plate on the back of the block, lo and behold, wrong bolt pattern. He got a Lakewood scatter shield, block plate and all, I installed that. We couldn't have used a 66 Fairlane bell housing because the factory trans was a top loader, we had an iron BW T-10. That would have fit the block,but not the trans, hence the scatter shield. I got it all together, installed the starter, and upon attempting to start it, it cranked, but made a nasty,nasty noise while spinning the motor.Seemed that the 164 or so toothed Falcon 260 flywheel was about 4 teeth too small, a '66 Fairlane 289 4 speed flywheel was the right thing. Out came the trans(again),off came the scattershield, off came the flywheel, on went the new slightly larger unit, and we didn't get too far before we learned the Falcon pressure plate didn't bolt to the Fairlane flywheel. Too small. Off to the clutch shop, got the correct pressure plate, but had to use the slightly smaller Falcon clutch disc. T-10 and Top Loader had a different spline. Got this whole mess together, finished final assembly on everything, actually drove the Falcon,timed and adjusted everything,and when we were sitting at a signal, it was in first gear, I had my foot on the clutch, suddenly the clutch pedal hit the floor as I felt something break,and the car lurched forward,killing the engine. Fortunately, no one in front of us. The Z bar from the frame to the block broke. Got the car home, he went to the Ford dealer again, ordered a new Z bar. When I looked at it, I could see how it broke. It was pretty light duty. We took it to a welding shop, the guy there gusseted it, in it went, the Falcon was working!!! It was a real test of our patience, fortunately parts cost a lot less then than they do now. That was a lesson on engine rebuilding and adaptability you didn't find in a college auto shop manual. He should have bought a 66 Nova 283 4 speed instead of that Falcon Sprint.Hindsight,again,to the rescue,just not in time.
