Old 12-09-2016, 10:53 PM   #1
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: Lifter rule in Stock
Originally Posted by Bob Mulry View Post
Hi
If there is an accident and the positive and negative crushed would still have a short and you have not addressed the issue of protecting both the front and rear batteries............
If wanted you could control the front battery with a constant duty rely.......
Sorry I hijacked thisthread....
Bob
That is correct Bob. For safety reasons I don't think a front and rear battery should be allowed. Also why is a cut off switch only required for rear mounted batteries?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 12-10-2016, 12:55 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
They should allow a maximum of 2 batteries and allow them to be located in the trunk for safety reasons, much the same that was done to allow..............
Front disc brakes......
Aluminum seats..........
Roller rocker arms....
Solid rear axles in IRS cars.......
Aftermarket rods, pistons and valve train.....
Full cages that extend through the firewall.........
I am still trying to figure out the safety advantage of an aluminum radiator...
I could go on and on about the STOCK rule changes for safety, but I will stop now..........
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 12-10-2016, 01:28 PM   #3
junior barns
Liked 20 Times in 14 Posts
Sorry on hijacking this thread but when did NHRA allow aluminum radiators as replacement? I have been out of racing for a while!
junior barns is offline   Reply With Quote
Old 12-11-2016, 02:35 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Lifter rule in Stock
Yup, for about two years now. Jim
Old 12-10-2016, 01:34 PM   #5
Tony Goodman
Liked 18 Times in 4 Posts
The Safety people at the track would know that all door cars have their battterys in the back and controlled by the master cutoff switch.
Tony Goodman is offline   Reply With Quote
