#1 | |
Liked 5,125 Times in 1,953 Posts
Somebody try and let us know ....
Liked 91 Times in 29 Posts
Please excuse my ignorance. But does this mean we can now run a solid lifter type cam in a hydraulic cam engine. IE a 396 350hp. Or just solid lifters on the hydraulic cam.
Bruce Cameron 1969 Nova E/S 1968 Camaro SS/I |
Liked 223 Times in 73 Posts
Since any duration is allowed I don't see why someone couldn't grind slight clearance ramps (just a couple thou) into them, but it doesn't seem worth bothering with.
#4 | |
Liked 799 Times in 236 Posts
![]() You can be down around .002 (hot) with a solid lifter on a 'hydraulic' cam lobe. Basically, as close to '0' as you can without hanging the valves open. A good rule of thumb.... on a typical iron head/iron block setup, you need around .003 more lash 'cold' than what you want it at 'hot' to allow for expansion. ie: .006 cold will get you .003 hot. Iron block/alum. heads & alum. block/alum. heads expand differently than iron block/iron head, of course.
"That'll never work....." Last edited by Alan Nyhus; 12-08-2016 at 10:09 AM. |
