Liked 14 Times in 10 Posts
I know this should be obvious, but if your combination already uses hydraulic roller lifters you can convert to solid rollers now?
Liked 7,887 Times in 1,753 Posts
It seems to me that going from a heavy hydraulic roller to a (fairly) light race-type solid roller should do wonders for the RPM potential of a bunch of modern Stockers!
Liked 719 Times in 220 Posts
Seems to me that after a lot of good intelligent questions have surfaced and been discussed, a rule clarification will probably be forthcoming. Yes, Billy, the solid roller lifter comment is a real good probability that RPM's might possibly be affected for good. I know that a mechanical lifter camshaft has clearance ramps included on each end of the lobe configuration to allow for lash, and that the overall lift also compensates for valve train lash. If you tried a set of mechanical lifters on your existent hydraulic cam, what would you use for lash on an initial effort before replacing the cam?We're talking going to a test and tune,not some kind of national event.
#4 | |
Liked 21 Times in 8 Posts
I assume that would have to be at or near operating temperature. Also, how much would you gain over these "Limited Travel" lifters?
This new rule is smart for us Racers that have lost good motors to those JUNK Ceramic Lifters!!!! and for NHRA to check cams.
Liked 7 Times in 5 Posts
Does this mean that Hydrualic rollers can be replaced with Solid Rollers?
Liked 69 Times in 32 Posts
Not sure in the roller stuff, but that is where
You would see the largest gain not flat tappets.
Ron Mattson 5015 STK |
Liked 184 Times in 113 Posts
Holy Super Stock Batman !!!
Stockers with SOLIDS ! ![]() D |
