Old 12-06-2016, 05:58 PM   #1
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Lifter rule in Stock
I just emailed NHRA Tech to get clarification on the new language. This is the response:
"The intent was/is to allow the use of a solid lifter in place of a hydraulic, you may not replace a flat tappet with a roller.
Thanks
Joey Gorman
NHRA Assistant Regional Technical Director
Office-(317)-969-8609"
...and there you have it.
It would have been so easy to add the above statement to the rule change!
As written, it creates all kinds of conclusions and assumptions by engine builders and racers
Old 12-06-2016, 08:46 PM   #2
Liked 10,721 Times in 2,232 Posts
I'm going to keep my hyd. lifters, solids would be a lot noisier and then I would have to keep them adjusted, and that might..............would cut into my adult beverage time.
Old 12-07-2016, 01:38 AM   #3
Coleydog
Liked 53 Times in 38 Posts
Ok, I'm a little slow sometimes, I was about to buy some good hyd lifters, can I instead buy solids now? Or just wait till all those hyd lifters hit the for sale page?
Old 12-07-2016, 11:10 PM   #4
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
X2 on that Larry!!
By the way, since lift will be checked at zero lash but you wouldn't run a solid at zero lash, I assume you have to give up some lift if you change over.
Mike Moller
NHRA 203 Q-R-T/SA
Old 12-07-2016, 11:31 PM   #5
Liked 5,125 Times in 1,953 Posts
Wink Re: Lifter rule in Stock
Originally Posted by MikeMoller View Post
X2 on that Larry!!
Yes, but I don't think you need .006. A lot of older motorcycle exhausts were around .003.
Somebody try and let us know ....
Old 12-08-2016, 12:34 AM   #6
killintime6968
Liked 91 Times in 29 Posts
Please excuse my ignorance. But does this mean we can now run a solid lifter type cam in a hydraulic cam engine. IE a 396 350hp. Or just solid lifters on the hydraulic cam.
Bruce Cameron
1969 Nova E/S
1968 Camaro SS/I
killintime6968 is offline   Reply With Quote
Old 12-08-2016, 01:52 AM   #7
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Since any duration is allowed I don't see why someone couldn't grind slight clearance ramps (just a couple thou) into them, but it doesn't seem worth bothering with.
Dave Muller is offline   Reply With Quote
Old 12-08-2016, 09:44 AM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
Yes, but I don't think you need .006. A lot of older motorcycle exhausts were around .003. Somebody try and let us know ....
Mark, this has been done for decades on high perf street engines.
You can be down around .002 (hot) with a solid lifter on a 'hydraulic' cam lobe. Basically, as close to '0' as you can without hanging the valves open. A good rule of thumb.... on a typical iron head/iron block setup, you need around .003 more lash 'cold' than what you want it at 'hot' to allow for expansion. ie: .006 cold will get you .003 hot.
Iron block/alum. heads & alum. block/alum. heads expand differently than iron block/iron head, of course.
"That'll never work....."
Old 12-07-2016, 08:44 AM   #9
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
I agree with the above. ^^
If that was NHRA's intent then the revision should have come out and stated that hyd. flat tappet lifters can be replaced with solids.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-07-2016, 09:34 AM   #10
Rick Schilling
Liked 14 Times in 10 Posts
I know this should be obvious, but if your combination already uses hydraulic roller lifters you can convert to solid rollers now?
Rick Schilling is offline   Reply With Quote
