Liked 14 Times in 10 Posts
I know this should be obvious, but if your combination already uses hydraulic roller lifters you can convert to solid rollers now?
It seems to me that going from a heavy hydraulic roller to a (fairly) light race-type solid roller should do wonders for the RPM potential of a bunch of modern Stockers!
Liked 719 Times in 220 Posts
Seems to me that after a lot of good intelligent questions have surfaced and been discussed, a rule clarification will probably be forthcoming. Yes, Billy, the solid roller lifter comment is a real good probability that RPM's might possibly be affected for good. I know that a mechanical lifter camshaft has clearance ramps included on each end of the lobe configuration to allow for lash, and that the overall lift also compensates for valve train lash. If you tried a set of mechanical lifters on your existent hydraulic cam, what would you use for lash on an initial effort before replacing the cam?We're talking going to a test and tune,not some kind of national event.
#4 | |
Liked 21 Times in 8 Posts
Liked 184 Times in 113 Posts
Holy Super Stock Batman !!!
Stockers with SOLIDS ! ![]() D |
Liked 373 Times in 131 Posts
![]() One step closer to SS for sure Dan ![]()
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 1,919 Times in 432 Posts
If that is the case, then a lot of stockers are about to gain a lot of RPM, and spend a lot of money. This could get really interesting. Or really stupid. Maybe both.
Alan Roehrich 212A G/S |
Liked 783 Times in 195 Posts
Alan, that usually goes hand in hand. It's like the chicken and egg thing.
#9 | |
Liked 320 Times in 102 Posts
Now I can print it off and put it in the racecar glove box with all of the other NHRA explanations.... Bob
#10 | |
Liked 210 Times in 88 Posts
Phil Vos |
