Old 12-05-2016, 11:39 PM   #1
Casey Miles
Liked 508 Times in 92 Posts
Default Re: Lifter rule in Stock
If I misunderstand this change, sorry! The guys who use solid lifter engines are getting screwed over do to no chance on manipulating the lifters. It's bad enough that .010 in a hydraulic is considered OK by NHRA. The engines HP were based on the lifter working the way the manufacturer designed it, not the way they are now with a built in lash. Might as well let everyone use solid roller cams and get over with it.
Casey Miles
248H Stock
Old 12-06-2016, 12:08 PM   #2
west coast
Liked 230 Times in 75 Posts
If all cars can have roller lifters then what are the penalties for HP all non roller lifter cars get HP, lets say 40 hp. What are the rollers lifters and cams worth, don't tell me they there are no gains there. I few people cry about there ceramic lifters coming apart now they want roller lifters for free. Nobody forced you to put ceramic lifters in, the rules don't state you have to use ceramic lifters.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 12-05-2016, 11:23 PM   #3
SSDiv6
This is the actual language on the 2017 rule change.
It's not clear enough and it needs to be explained better.
It does not say that hydraulic lifters can be replaced with solids.
It still gives the requirements for checking hydraulic lifters.
Name:	2017 Cam Rule Change.JPG
Old 12-05-2016, 11:50 PM   #4
After re-reading this, I think it gives the okay for ceramic bottom lifters, ..about 15 years after the fact.
I'll have to call my law firm , Dewey, Screwum , and Howe, and get an interpretation.
Old 12-06-2016, 12:14 AM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: Lifter rule in Stock
It also still says you must use OEM rocker arms or adjustable push rods (not both)????? The roller rocker OK has been law for several years? Jim
