Liked 880 Times in 311 Posts
Do an A-B-A test of the manifold change at the track to check that out.
The 1.96 you are talking about probably uses the heavier V8 planetary. Could the original owner be mistaken and had a 1.98 that is the lite weight 6 cylinder planetary? There is a substantial weight difference, I'm talking major lbs... It takes some time and HP to get that heavy planetary moving. The 1.98 also has one of the best % drop in shift RPM of all the aftermarket ratios. Anything lower than a 1.98 has more than a 50% drop in RPM and becomes power and weight as well as converter sensitive. Just the difference in (both trans were tricked out with lt weight parts) the 1.76 & a1.98 in my 3175 lb 660 HP Camaro was almost .25 sec.
Adger Smith (Former SS) Last edited by Adger Smith; 09-11-2016 at 06:34 AM. Reason: sp |
Liked 319 Times in 68 Posts
I knew someone sharper than me would have some answers.
Lee Valentine 1661 STK |
Liked 133 Times in 76 Posts
I don't know where you are but the weather for us has been slow this year. Comparing log books from last year same dates to this year et's are slower as the weather has been hot and humid.
I'm in Ontario Canada and hot hear also which is prob playing a part ! Thanks everyone for the help!
Liked 10 Times in 8 Posts
What Motor do you have?
330 hp Vortec head in my car. Powerglide 2.10 low gear, 5.38 rear and a 94 inch circumference rear tire and you should make the 1/4 mile finish line.
F Federico NHRA J/SA |
Yes 330 hp car, i will check tire size i cant remember off hand,i'm not looking to brake records but think car should run 6.85 on a good day ? How fast are these cars going with 385 hp motors ? I am new to this crate motor stuff thanks
Yes, .85 is respectable in the 1/8. But , its all relative, depending on class. 3rd Gens with a 330hp generally run F G or H. In H 6.85 is fast, in F, not as much. How much does the car weigh?
