Thread Tools | Search this Thread | Display Modes |
327 shortblock, 3892657 block, ATI balancer, Charlies oil pan, Ross 99578 piston, needs freshening, SOLD
McLeod Clutch (used), GM crank, 153 tooth, aluminum flywheel, Chrysler input, 29 pounds total, disk measures .257 $900 McLeod Clutch missing disk, for rebuild, lightened aluminum flywheel, 168 tooth. $600 Dynamic Convertor, 350 input, 6100 stall behind small block SS motor. SOLD Lakewood Bellhousing, for chevy, (used) SOLD Rossler T-350 2.75 first. Auto 1-2. PRN321 - SOLD Leon Miranian T-350 2.52 first. PRN123 - SOLD Varishock, double adjustable, bolt on coil over conversion for GM A-Arm, VAS 162M1-425, spherical stem on top, ½ inch ball bushing on bottom. Compressed length 11.4, extended length 14.6, (New). $600 VariShock, double adjustable, eye/bushing on one end, post on shaft end (new), 14 inches compressed, 22 inches extended. $375 QA1 HAL shocks, single adjustable, big end has a bushing, shaft end has a post. 13 inches compressed, 20 inches extended. (used) $125 Crane Hi-7 ignition, Coil, (used) $250 Computech DataPro-45 data logger, Comes with instructions, installation kit, cables, junction box and data logger, never used, SOLD Computech DataPro-45 junction box, (used), $150 Weld Draglite front wheels with Moroso tires (7.60-15), (used) $325 GM Performance Parts Aluminum Valve Covers, SOLD Small block, black (new) pn. 141-116 2 axles and C-clip eliminators $225 35 spline, 5 ON 4 3/4", for 12 bolt (used) ProCar seat, (new) SOLD SteveFicacci@yahoo.com 973-714-1373 or send me a message on classracer Last edited by Steve Ficacci 1142; 06-20-2017 at 10:29 AM. Reason: Sold Items |
Liked 2 Times in 2 Posts
Interested in the 327...where are u located..?
Northern NJ
