Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 06-30-2016, 09:43 AM   #11
Chuck Garey
Liked 10 Times in 7 Posts
Default Re: New concrete shop floor coating recommendations
Garage floor was done yesterday Looks fantastic and very good job I would highly recommend any one in the Dallas area to try these guys out.
Tried to upload photo but says too big can't seem to figure out how to load it
Chuck Garey is offline   Reply With Quote
Old 06-30-2016, 01:15 PM   #12
cad
cad's Avatar
Liked 91 Times in 51 Posts
Put the pic on photobucket and then copy the IMG URL from there....free accounts...
cad is online now   Reply With Quote
Old 07-06-2016, 03:45 PM   #13
Chuck Garey
Name:	garage floor.JPG
Old 08-19-2016, 09:28 AM   #14
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Did two garages.
Used epoxy base.
First Garage was a new floor and did not need to sand it.
But thoroughly used the Acid and Water.
Made a mistake and started painting before the floor was perfectly dry.
Over time the one side that was apparently damp is pealing.
Eventully will need redone from scratch but fine after 10 years.
Other side that dried properly holding up just fine.
Second garage needed a thorough sanding because of grease.
Then the acid and water rince.
Waited a whole day for the floor to dry this time.
It came out looking much better having a smoother look.
Consider the sanding as it cleans up the imperfections.
D
Old 09-01-2016, 06:34 PM   #15
Jimbo17
Jimbo17's Avatar
Liked 2 Times in 2 Posts
I have always used a concrete stain.
It's inexpensive for a few gallons in either a light grey or a dark grey color.
The nice think is living here on the West Coast of Florida the hot car or truck tires will not lift the stain like they do with most paint products.
Every three or five years if it starts looking old I simply re stain it again.
One easy way to make it look new again after a few projects is to mop the floor with a mop and simply put some Dawn hand cleaner on the floor and it removes any grease or dirt and makes the floor look brand new again.
One other tip DO NOT ADD ANY SAND in with the stain trying to make it less slippery because the sane will wear off the floor in high traffic areas making your floor look stupid.
Jim Hill
Jimbo17 is offline   Reply With Quote
Old 05-22-2017, 07:20 AM   #16
Brandon Davis
Originally Posted by SGSST109E View Post
Sherman Williams has some good products. A concrete stain. Its a available in tints or just clear. It is solvent based. I rolled it on, it gets tacky very quickly. Gas, oil etc. doesn't effect it even after days. Tires won't pull it up. Makes cleaning up so much nicer. MY garage is 30' x 30'. New concrete floor just swept it clean before. MAchine floated floor that was very smooth.
I have been doing a lot of research on this topic, I am very interested in this product...Is it the H&C color top solvent based solid color concrete sealer? How does it do resisting chipping, like from jack stands? How long have you had it down now? Did you have to clear over the stain?
Thanks
Brandon
Brandon Davis is offline   Reply With Quote
Old 07-14-2019, 03:07 PM   #17
Stick cars rule
Stick cars rule's Avatar
im sure ken has finished his floor by now and hope it worked out good.as a concrete polisher I thought I would share my thoughts.preping floor with acid does not do much.grinding thru the cap is a must.not only does it smooth the floor,the coating will penetrate for a strong bond. also using densifiers before a coating will effect the bond. I offer grinding services for diy home owners.look for a concrete polisher in your area for prep, it will be worth it.
Scott justo.
2009018 lc22r
Stick cars rule is offline   Reply With Quote
Old 07-27-2019, 12:05 PM   #18
House of Darts
Liked 20 Times in 15 Posts
For your shop use the silver foiled bubble wrap insulation over the stone and before the rebar goes in. Keeps the floor cool/warm and is an excellent vapor barrier. Don't forget to add a thicker pad area if you will be adding a lift in the future. As for a surface finish, this is a pore sealer, 50/50 mineral spirits and polyurethane 1 months after the concrete cures(rinse and maybe some vinegar.. Unlike modern sealer that are acrylic and don't penetrate much.They are a top coating that wears and not solvent(brake cleaner) friendly. Being deep in the pores, the poly doesn't let oil seep in. You never have to re do it.
House of Darts is offline   Reply With Quote
