The parts listed below are plus shipping. Reasonable offers accepted. Clearing out space.
Ford 9" aluminum center section, Richmond 6.00 pro gear (few runs), steel spool, 35 spline, aluminum yoke, all Moser set-up, drop in and go, $1,100 Tools and Equipment Autometer 17 channel datalogger, NEW in box, $1,500 #9325 8 EGT #9342 Volt reducer #9331 25 psi pressure sensor #9381 sensor cable/connector #9355 RPM sensor #9340 Accelerometer Parallel/Serial converter and cables Demo software Installation and operation book Valve Spring removal tool, hand operated, used, $35 Autometer, part # 4469, low temp water temp gauge, 60*-210*, 2 5/8, full sweep, electric, certified by autometer, installed but not used, $80 Converters TCI 7” converter 6400 flash (12 runs) $575 ATI 8” converter 6000 flash (FRESH 0 runs) $650 TCI locking dipstick tube for PG, used $15 Tires/Wheels Summit part #G1495 wheel screws, gold iridite, (35), NEW in package, $10 Centerline center covers, NEW in pkg, $10 Chassis/Frame components 67-68 Camaro OEM front tie rod ends, used, $25 67-68 Camaro sbc OEM frame mounts, used, $20 67-68 Camaro, sbc solid motor mounts, used, $20 RCI, jr dragster restraints, expired $20 (2 sets) RCI, 5 point restraints, part # 9210, black, good thru 6/08, NEW in box $40 Carbs/Fuel/Pumps Boburka 207 Q jet $550 Carb Shop 213 Q jet $450 BG phenolic 1” 4 hole spacer $30 BG 400 pump, (1), remanufactured $275 BG part # 170036, O ring kit, NEW in package $6 BG part # 150889, #12 bulkhead fitting, NEW in package $20 Mallory 4 port regulator, remanufactured $65 Q-jet 1 inch aluminum spacer, used, 3 available, $10 each Ignition/Electrical Crane Hi Fire part # 730-0092, PS 92 coil, NEW $65 Crane Fireball ignition tester/tach calibrator, NEW $75 Crane part # 9000-1000, Hall Effect Crank Trigger, NEW in pkg, $125 Powermaster starter, part #9400, for sbc, NEW in box $225 MSD part #8276, non magnetic pick-up, (2), NEW in package $75 each MSD part # 7555, spark pick up adapter for cam sync, NEW in pkg, $75 MSD part # 8980, spark timing control, used, $75 MSD style magnetic pick-up, 2 wire, NEW in package $30 Powerhouse, part #102100, Innovate LM-1 basic kit, Oxygen sensor, NEW in package $300 Misc Holley and Crane spark plug wires for front mount distributor, used $25 for all Pistons/Rods/Shortblock JE pistons, (2), with pins, part #386973, for 327 +060, NEW $125 pair CP pins 875-2250-10CP35, (8), used $20 SBC 9 GM rods, polished beams, 7 Summit rods (5.7), 7 Ross/2 BME pistons (350 +060), used, $200 SBC steel deep oil pan w/ kick outs (used), w/timing chain/gears (new out of box), t/c cover, $50 Heads/Valvetrain/Intake components Jesel, rockers, part # CABL/CABR, 1.8 ratio, set of 8, NEW in box, $450 Jesel, rocker, part #CLFR80, 1.8 ratio, .300 offset, NEW, $60 Jesel, rocker, part #CLFL80, 1.8 ratio, .300 offset, NEW, $60 Jesel, rocker, part #CAAS60, 1.6 ratio, no offset, dyno time only, $45 Jesel, screw cups, (5), NEW out of package $75 pack Jesel, rocker bearing/trunions (5), NEW in package $15 Jesel, bearing/trunion snap lock rings (5), NEW $7 Comp Cams, part #611-16, 11/32 super lock, hardened steel, NEW in package $17 Comp Cams, radial 11/32 lock, hardened steel, NEW in package $20 Comp Cams, valve springs, used (dyno) springs (6 sets), part # 086, 099 and #947 Comp Cams, used cam, 4482S/4496S R106 X4920, standard size, no swap, $80 Powerhouse/Comp Cams, part #101215, pushrod length checker, 6.8-7.8, NEW in package $17 Powerhouse/Comp Cams, part #101220, pushrod length checker, 7.8-8.8, NEW in package $17 Powerhouse, part #102114, stainless steel bung/plug kit, NEW in package $6 Powerhouse, part #301090, spark plug index washers, NEW in package $10 Powerhouse, part #301020, 14mm air hold fitting, NEW in package $5 Mr. Gasket, part #5812, sbc intake gaskets, NEW in package $17 Mr. Gasket, part# 102 or 102G, sbc intake gaskets, NEW in package $8 Mr. Gasket, sbc intake gaskets, NEW out of pkg, 2 sets, $10 Mr. Gasket, part #106, sbc intake gaskets, NEW in package $10 Mr. Gasket, part #976, hex head header bolts, 5/16-18x3/4” 14 count, NEW in package $6 Mr. Gasket, part #917, hex head header bolts, 3/8-16x1” 12 count, NEW in package $7 Mr. Gasket, part # 5425, baffled grommets, fits 1 ? ID hole, NEW in package $5 Manley Valves, 8, used (spare), 5.100 long, $75 Manley Valves, 8 exhaust, 200 long, NEW in box Manley, part #13161, hardened steel locks (16), 10 degree standard, NEW in package $25 Ferrea, part #K10053, 11/32 standard radial Titanium lock, 10 degree, NEW in package $100 Ferrea, part #E11016, Titanium retainers, 10 degree (16), NEW in package $300 Fel-Pro, part # 1628, valve cover gaskets, (2), blue molded steel core, NEW in package $40 each CSR billet aluminum valve cover grommets, pair, NEW out of package $30 Header bolts, 12 point head, 5/16-18x3/4”, NEW in package $6 Misc set of 10 degree, 11/32 standard, valve locks, NEW out of package $10 Collectors Merge collectors, 2” tube, 3 ? collector, 14 ? length, not coated, used, $150 Collectors, stainless, 1 7/8” tube, 3 ? collector, 9 ? length, NEW, $225 Last edited by Ronnie Smith Jr; 02-29-2008 at 10:50 PM. Reason: Parts sold |
Liked 31 Times in 16 Posts
Ronnie,
Interested in a few things. Do you have an e-mail I can get with you at? |
Liked 101 Times in 27 Posts
hey Ronnie------could you possibly find that Chevy ll in the garage, a white K/SA when we raced against each other at Elk Creek many moons ago ?????..........if you find it let me know........I think we were a lot smarter then !!!!!!! hahahahah
Rusty,
Wish it was still in my garage. I would love to have it back; Dad more so than I. We think we know where it is located, but we are not receiving "cooperation" with return phone calls from people we have reached out to. We kick ourselves each day for selling it. It was the best race car we ever had. It has a lot of sentimental value to Dad and I and I would like to buy it back to restore. If for nothing else, just to be able to sit and reminisce. Hope all is well with you and the family. Merry Christmas and a Happy New Year. Ronnie, Jr. |
The below parts have been sold:
Slicks wheel studs Jesel shafts Tilton starter tire gauge Thank you and Merry Christmas. Ronnie, Jr. |
LSM Valve spring tool sold.
Megaphone collectors sold. Please look at the ad for updated info. Thank you to those that have inquired. Ronnie, Jr. |
