Old 07-20-2016, 01:07 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Front shock info please
Best shock control on that type of car would be a Santuff .
They are infinitely more adjustable than just about any other shock on stock type suspensions.
I'd also recommend their front springs, they can hook you up with a spring that will give you the desired ride height without cutting coils while giving the correct spring rate for the weight of the car.
You have to maintain adequate travel for consistent traction ,SST cars don't need the instant reaction of a SG car so I usually set them up with about 4" of travel.
