Old 07-12-2016, 08:57 AM   #2
V M Kauffman
Default Re: 302 SBF Dart block potential cooling system issue
On small block Fords you should run a across over tube on the back of the intake put a tee in middle of tube or hose with a cap on it. These Ford have a bad habit of trapping air in the cylinder heads. Most intake have bosses you can drill and tap for fittings. After filling cooling system always bleed air at that point. FE's included.
V M Kauffman is offline   Reply With Quote
