Old 05-29-2016, 01:17 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Re: Vac pump destruction / mystery
Originally Posted by CFMCNC View Post
Pics of bearings and rest of engine combo 8700-8800RPMs?.Bill C.
Why the question mark after the RPM?
No pics.........the bearings need to be replaced. What I see are bearings not getting sufficient oil. What exactly are you looking for?
I've used HV pumps ,STD volume pumps ,3 different oil pans , several different screen or baffle combos , 3- 4 different blocks , restrictors , no restrictors , WIX racing filters , K&N filters , 2 different cranks .........
Old 05-29-2016, 03:11 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What is the main bearing diameter, what brand oil and weight ?
Old 05-29-2016, 03:34 PM   #3
joespanova
Why would you ask me what the main journal dia. is? 2.450 / 2.449..........the clearances are .0025 /.003.
The current oil is Brad Penn. Break in oil ( 30 weight ) ...........this inspection is only after 5 trips down the track.
BTW.......this is a 350 inch engine.......
Old 05-29-2016, 07:19 PM   #4
Ed Wright
Ed Wright's Avatar
Because journal diameter tells you how much oil clearance is needed. .0025"/.003" is fine. How about your rod journal dia & clearance?
I ran a vacuum pump on mine before I made an SS legal car of it. I used the same pump and clearances then as now. I have seen no difference in bearings. I doubt it's the pump.
How much oil pressure?
Ed Wright 4156 SS/JA
Old 05-29-2016, 07:48 PM   #5
joespanova
60 PLUS......
Did you lose any power worth noting WITHOUT the pump?
At this point I have little choice but to run it without the pump. The bearings looked as though there was trash in the engine , as bad as I've seen............but , it may well have been bearing decomposition getting in the oil?
I cant take any pics now since my wife has the camera and she's out of town.....
Old 05-29-2016, 08:39 PM   #6
Ed Wright
Ed Wright's Avatar
On my old chassis dyno, taking the belt on & off the pump was a consistent ten hp at the tires. Probably worth 12 to 15 hp on an engine dyno. I can not imagine the vacuum pump causing a bearing problem. I also plug the bypass in the oil filter mount, so all oil goes through the filter. Keeps crap out of the bearings better. 60 psi has always been enough in mine. Ran 45 for years with zero issues. I'm no professional engine builder, so more knowledgeable pros here may have more info.
Old 05-30-2016, 12:14 AM   #7
CFMCNC
WE use Brad Penn break in oil on our dyno a lot, but of all the break in oils we get the BP out of the engine before it goes in the car ,WE use vacuum pumps on most of race engine we build with no failures related to the vac pumps.Bill C.
CFMCNC is offline   Reply With Quote
Old 05-31-2016, 10:25 AM   #8
RJ Sledge
Liked 294 Times in 93 Posts
Although my application was a Stocker, low to mid ten Ford small block, I had the same problem after about 5 or 6 passes. I had set my oil pickup clearance too short and it was starving my bearings. Set it to .400 and I never had any more problems. You can get it too close.
Sometimes its the little things you can take for granted.
Hope you figure it out.
An Accumulator can also help.
RJ
RJ Sledge is offline   Reply With Quote
Old 05-31-2016, 02:53 PM   #9
joespanova
RJ
Thanks.......great point. Mine may be a little too close too @ .250ish. or less even
The only way to fix is to take a 2x4 and wack the pan bottom a little.
