#11 |
John DiBartolomeo DRC Race Products DragRacingActionOnline.com |
#12 |
Wrong. We are in the trucking business so I deal with this stuff all the time. The only way you need cdl is if the combination of the truck and trailer is 26,001 or more unless transporting hazardous materials. So you would be fine with the Yugo Charlie or most any dually or 3/4 ton truck.
#13 | |
#14 |
Now that is the truth, a lot of the DOT officers use a lot of interpretation into something they don't always know.
#15 |
Charlie every thing is by west coast rules, NHRA is in Glendora Ca part of the west coast
Tony Janes 7941 STK, SS |
#16 |
Liked 2 Times in 1 Post
Thanks for the help. Looks like I have some reading to do. I checked and the truck is 10,500lbs gross and the trailer is 12,000lbs gross. It is confusing. It's like it is all up to the state you're in and the officer. Thanks again. Derek
Derek Hake 4459 H/SA 69' Roadrunner |
#17 |
Jeff Teuton had some good information on this subject in another thread not too long ago. He referenced a section of the FMCA manual (Federal Motor Carrier something or other) that pertained to transporting personal property for other than commercial purposes. That thread dealt with the concerns mentioned here. It would be a good idea if you can find it in search. It was very informative from a person who knows. If you just try to figure it out on your own, chances are you will only get more confused.
Jeff Blanchard 353C / Stock |
#18 |
Liked 172 Times in 81 Posts
I was hoping someone would bring up the motorhome thing. I have a CDL with an air brake endorsement, what we call a class 3 so that means any straight truck towing a trailer not over 10,000 lbs. I'm legal in BC but always wonder if I'm legal when I travel south. Our motorhome has what is basically a passenger car plate.
Jim Mantle V/SA 6632 |
#19 |
Liked 52 Times in 17 Posts
What I would recommend is a Non Commercial Class A licence, non CDL.
I have one after taking the test with my own equipment, using a GVWR over 26K combined. Borrow one to get it done if ya must. There is also a requirement for a GVWR of over 16K combined that also puts you into Class A, just pick where you need to be. More is better here. Along with the Non Commercial Class A you can get an Air brake endorsement. There's also a bunch of confusion with all of the huge motorhomes going down the road these days. Now you have retired folks driving with lot's of weight and air brakes and a driver that holds a class C who thinks they're legal, they're not ! This is where the 16K thing came along years ago but that could be obsolete by now.
Bernie Cunningham 7053 STK Last edited by Bernie Cunningham; 05-12-2016 at 12:09 AM. |
#20 |
I should have mentioned that when I did this, the DMV personnel went into a tail spin because they couldn't figure out what written test I needed to take.
I took one and passed but then I had to take another of lesser value to conform on that particular day. HUH ! I still reckon it's the safest way to go to cover your ***. Ca.only requires a non doctor form every two years and that takes away the commercial interrogation on the road. BTW. I have never gone thru a scale and I have never been pulled over, I drive fast !. He He Hope this helps
Bernie Cunningham 7053 STK Last edited by Bernie Cunningham; 05-12-2016 at 12:11 AM. |
