Old 04-27-2016, 07:06 PM   #7
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: 12-Bolt Spool Bearing Pre-Load
I've had good luck with the "Super Shim Pack" kit from Randy's Worldwide (www.ringpinion.com). The shims fit between two halves of a machined spacer, which makes installing them MUCH easier. They also have have the crush-sleeve replacement spacer and shim kit that Larry mentioned as well.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
