Old 03-29-2016, 07:23 AM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Parting out 2009 5.7L Hemi with eagle heads (More items)
I am parting out a 2009 5.7L Hemi Truck engine that had 5500miles on it. Please contact me with parts you might need. I will continue to post photos and parts packages as I dis-assemble the engine. I plan on keeping the block but everything else must go. Below are a few of the packages I have put together to sale. Please see ebay ads below for more photos:
5.7L / 6.1L / 6.4L Hemi OEM Stamped Steel Rear Sump Oil Pan $165 OBO
Oil pan came of a 2009 5.7L hemi truck engine. The engine had 5500 miles on it before the pan was pulled off. The Oil Pan will be sold with the OEM pickup, OEM Oil Pump, OEM Dipstick, and the OEM windage tray. Everything is in good used condition.
See ebay ad below for more photos:
http://www.ebay.com/itm/182069376812...84.m1555.l2649
2009 5.7L Hemi Crankshaft - Only 5500 miles of use - $325
This crankshaft came out of a 5.7L 390 Horsepower engine used in a 2009 Dodge Pickup. The engine had 5500 miles on it before being removed due to a wreck. The bearing wear also suggest that there was low mileage as there is no significant signs of wear. The crankshaft is in very good shape and as apart of the sale I will also send the current crankshaft bearings as well. There is some surface rust on the back of the crankshaft were the flywheel mates up but its something that easily be cleaned up by hand with sand paper. See below for more information on the improvements made to the 5.7L in starting with the 2009 model year.
All items are sold "AS IS" and priced to move. Please send me a message if you have any further questions.
http://www.ebay.com/itm/182073919330...84.m1555.l2649
2009 5.7L Hemi Aluminum Pistons and Connecting Rods - Only 5500 miles of use - $400 OBO
This Pistons and Rods came out of a 5.7L 390 Horsepower engine used in a 2009 Dodge Pickup. The engine had 5500 miles on it before being removed due to a wreck. The rod bearing wear also suggest that there was low mileage as there is no significant signs of wear. The pistons and rods are in very good shape and as a part of the sale I will send the rod bearings as well. See below for more information on the improvements made to the 5.7L in starting with the 2009 model year.
http://www.ebay.com/itm/182073974063...84.m1555.l2649
Contact me for more questions. Buyer pays for ride.
Follow link to see all engine photos: https://onedrive.live.com/redir?resi...t=folder%2cjpg
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Search this Thread:
Advanced Search
