Old 03-07-2016, 01:59 PM   #29
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: oil pump help
Originally Posted by Jim Hanig View Post
Mike what do you think caused the shaft to break? I have raced chevys for 50 + years and never had a melling, chevy pump fail. Jim Blair does low pressure pumps Pierre s.d.
I have found over the years that you are much better off using a product that is specifically designed for a racing application instead of using a modified passenger car type product. I found this out the hard way. I use a Moroso billet oil pump a system one oil filter and racing quality engine oil just to name a few. Just Google Meling oil pump failures and you can get some info. The pump that broke was a Melling M55. Snapped off at the neck just below the bolt flange. It destroyed that short block.
Mike Pearson 2485 SS
