Old 02-02-2016, 11:27 PM   #1
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Default Re: Questions on lifter bore correction
Listen to Dwight's advice, the bhj fixtures are about as bad as just leaving the block alone, we have a CNC mill at my shop that we do this job on, can't beat a CNC machine when it comes to exacting tolerances. We only charge $450 though and seeing that others are charging $500-700 to do it on a manual mill I might need to go up on pricing...lol
Allen Sherman is offline   Reply With Quote
Old 02-03-2016, 11:10 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
BHJ fixtures were like hooked on phonics,worked for me.LOL
Allen,
Ten years ago when I did lifter bores w/BHJ we got $375.00 SBC $425.00 BBC including bushings, by time took and bushings was how we come up with those numbers,CNC you can walk away some,manual machine pretty much stuck there.
Mike Taylor 3601
Old 02-03-2016, 11:51 AM   #3
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Allen, Without the fixture, what do you use for a reference, and how do you choose the angle ? thanks
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 02-03-2016, 01:28 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Factory blueprints and a CNC is the best.
Old 02-04-2016, 05:21 PM   #5
carl hinkson
Liked 18 Times in 10 Posts
I do all my blocks in a HAAS CNC machine and we only charge 275.00 for machining lifter bores LOL. I guess I will have to go up.
carl hinkson is offline   Reply With Quote
Old 02-04-2016, 10:09 PM   #6
Allen Sherman
Banned
I'm $450 to bore block, install bushings and bore and hone bushings to size
Old 02-05-2016, 08:49 AM   #7
carl hinkson
Thats a good deal!!
