Liked 708 Times in 285 Posts
For a stocker application can I change lifter diameter? I plan on correcting lifter bore and bush but having a hard time finding quality lifter in my diameter. .921
Liked 335 Times in 182 Posts
Some Oldsmobile engines using .921 lifters 307 394 look into it
Liked 1,923 Times in 432 Posts
Last I looked, Stock Eliminator rules require the stock OE lifter diameter.
Alan Roehrich 212A G/S |
Liked 250 Times in 49 Posts
Alan is correct and it is often but not always checked.
Pete |
Liked 21 Times in 13 Posts
Mike, thanks for the info. sounds like a good thing that guy brought his motor to you.
Bill, thanks. about 6500-6700 rpm. I'll look close at valve-train geometry for rocker arm location and push rod length. Just trying to plan for how much bang for the buck. I understand that it all really depends on the lifter bore location error though.
Brian Carpenter Stock 1358 |
Liked 204 Times in 54 Posts
I have always had the lifter bores corrected in my engines. You can use a lifter tru and install bushings with the stock lifter diameter. Then you hone them to fit the lifters perfectly. You can also replace the bushings if you need to down the road.
#7 | |
According to the NHRA engine specs, the legal block for your HP rating, has the standard .875 hydraulic/flat tappet lifter and not the .921 hydraulic roller. Also, the .875 Chevy lifter is not the same as the Olds/Pontiac lifter. They have different oil band locations. |
Liked 783 Times in 195 Posts
Caution on using anyone's fixtures. I bought a BHJ for a BBC years ago and after getting blueprints from Chev, found that the BHJ was out as much as most blocks. Then you have to wrestle with the assumption that the factory design and specs are the most optimum for valve train geometry. At least you will get them consistent.
#9 | |
Liked 9 Times in 8 Posts
This was not brought up in the roller cam thread but it is a big reason why some guys are chewing thru lots of valvetrain parts..... did somebody mention.... "lifters"
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 02-02-2016 at 07:08 PM. |
#10 | |
