bbc team g intake 7525..bbc cyl heads...049 oval port
Weiand Team Gs # 7524 are single plane manifolds, designed to build power in the 2,000 rpm to 8,000 rpm range. Port-matching an intake to your heads can move the power band up another 200 rpm to 800 rpm. They have a raised plenum for increased flow and atomization, extended runners for improved flow velocity (most models), integral bosses for nitrous oxide nozzles (most models), isolated water passages for improved cooling, and cast-in carb linkage clearance........150.00.........bbc heads...353049 1970-73 402/454 Open...bare casting...300.00.........text for pics must sell asap......610 621 3395 located in the philly pa burbs
Reason: part number
