Liked 7 Times in 5 Posts
would the Tempo/Topaz 2.3L pushrod engine be legal with a cut down Australian head from the 250 AU six?
thanks, Roland |
Liked 805 Times in 245 Posts
Probably would be legal but kind of a stretch. The block & head have to have an OEM part number and the engine type had to be available in a production automobile but you can cut and hack to your hearts content from there. There have been other instances of parts from outside of North America being used as long as it is OEM. I would sure be checking on this with NHRA before I went too far though.
Liked 32 Times in 19 Posts
Jim, I do not know you but must respect your information. Obviously you have investigated the motors of your area of interest. Good Luck to you. Thanks for your comments.
#4 | |
I purchased the head from AK Miller many years ago. He cut one cylinder off each end of the head and welded a plate to each end. His customer then lost interest in the project so AK shelved it and when I was buying something else from him he told me about it so I purchased it because the price was cheap. It has a Ford casting number on it. They look similar to a Cleveland head. The bore spacing and head bolt pattern are the same as the Tempo 2.3L block. Roland |
Roland,
The fine point in the rule book is SS/MX states 'automobile engine' whereas the Comp Altered rules says ' automobile type engine'. That's why the Merc motor isn't legal as it is actually a marine motor and wasn't ever installed in a car. My opinion is that what you are proposing would be legal as the 2.3 pushrod shortblock is a production auto motor, the fact that the head wasn't orig intended for that motor doesn't seem to me to be an issue, it does have a Ford part number in spite of the extent of the mods. The other motor that I don't think is legal for SS is the Fontana 4 cylinder motor with a Yates Cleveland type head. As Ford didn't have a viable pushrod shortblock, they had a Chevy II block recast by Fontana with a Ford head bolt pattern, Ford logo and a Ford part number. Instant Ford motor! Once again, legal for Comp Altered, not legal for SS. Jim Caughlin |
Jim, With all the investigation and research on all the small motors what do you believe is your driving force? Research? Building one of the cars to prove it works?
If your car is "fast" in your opinion when it is done, how will it be judged? Do you just believe it is fast? based on previous motors you built? Without many competitors of your skill in your class, what is the standard against which you compare? Obviously you are very well informed and dedicated. My own stimulus was to be the class winner over multiple experienced racers with the same or similar combinations. |
