Old 09-29-2015, 08:59 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Re: Stick shift drivers by division
Curious as to what the clutch has to do with it, if it remains applied. ??
Yeah..........exactly
You either convert to clutchless internals or crash the crap out of the lugs. The GF5R and LS5000 are nothing more than a Nash with a few upgrades.
In my case mine's faceplated , does not have split sliders and as far as I know needs some power "interrupt" at gear changes. I could be wrong............he may be suggesting very low base , playing with c'weight and so on.......but I have no reason to attempt shifting mine clutchless.............I'm that good , really.
Old 09-29-2015, 09:21 PM   #2
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
Division One
Wayne Truesdell
Joe Mendillo
Timmy Abbazia
Old 10-02-2015, 11:12 PM   #3
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by stefan callender View Post
Division One
Wayne Truesdell
Joe Mendillo
Timmy Abbazia
Alan Peters... not officially retired.
Mike A114
P/SA
Old 09-29-2015, 10:27 PM   #4
Liked 5,120 Times in 1,951 Posts
You use the clutch to get it out of the gear you're in..to take the load off the flank of the lugs.
It'll usually go into the next set of lugs to come along.
I suppose, if you pull hard enough, it'll come out of the prior gear.
I don't know about that T5 deal either. The last one I had wouldn't even shift over 6 grand,with the clutch!...Not until I slick shifted it.
Even then I wouldn't want to lean on that rail shift deal, without a clutch.
Old 09-29-2015, 11:36 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Dirk Ive had several emails and calls saying it won't work, no one will actually show up, arguments already that it needs to be a D1 or D3 track(racers in these divisions think the rest of us don't exist) etc etc. Last time I busted *** for 6 months getting 20+ sponsors over 7k for just one class and I had negative comments about that. Well I say wtf to that. Who else did that much for one class damn I just wanted to help some of my fellow racers out. I still would like to do something maybe if D4 has a real national open(not that 1/8 mile crap like at Ennis) I could round up some sponsors for class eliminations or something. Well see.......
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-30-2015, 12:25 AM   #6
55 Chevy
55 Chevy's Avatar
Liked 18 Times in 15 Posts
Hopefully you can count me in for a couple of races in division 6 next year.
Allan
55 Chevy is offline   Reply With Quote
Old 09-30-2015, 12:57 AM   #7
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Don't forget these long time Division 1 stick shift racers...
Jim Zane
Rich Oakes
Mike Papp
Old 09-30-2015, 09:38 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 304 Times in 102 Posts
Joe and Mark,
Shifting face plated trans without clutch just requires yanking the crap out of it,once you pull it out of the gear it's in, it falls in the next, My brother ran his Jerico for 5 seasons racing every weekend and shifted it clutchless 4 1/2 of them before he had to replace a slider and ring or 2.
As far as clutch goes you can lower pressure when not using clutch to shift.
I have shifted a few gears without clutch in a pro shifted trans by accident.
As soon as I have a face plated trans I most likely will shift without the clutch.
Mike Taylor 3601
Old 09-30-2015, 12:34 PM   #9
DonatoEng
Liked 8 Times in 5 Posts
Last time I ran my stick shift Dakota, I was invited to the barn to pull the trans so Tech could look at it. No one else in tear down could figure out what I was doing until I rolled out with it and put it on the bench.
Anyone else do that before ?
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 09-30-2015, 12:39 PM   #10
Dirk Olson
Liked 172 Times in 46 Posts
Ed,
It would great to work this out. We as stick racers are a minority. But I believe that given the right venue, we could make this work. Maybe we start slow by doing a S/SS Stick shootouts at Div races to spark interest?To find a location that is for everyone probably will not work just because of logistics but as they said about a spot in a corn field in Iowa "if you build it they will come". I believe that is the same for racers just not in the numbers we would like but we need to start somwhere.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
