Old 09-24-2015, 09:15 AM   #1
FED 387
Liked 332 Times in 180 Posts
Default Re: msd7al-3 problem
Ground heads to block !!!! anyway--- Belt defective and stretching??? check with Jesel ??? bet they can give you an answer--FED 387
Old 09-24-2015, 02:53 PM   #2
Duane Dagostino
reverse green and violet wires from the crank trigger to the box at the box see what happens to your timing....mine did the same as yours reversed the wires ,,fixed!
Duane Dagostino 1821 S/C, S/G
Duane Dagostino is offline   Reply With Quote
Old 09-24-2015, 10:27 PM   #3
voltdr
Liked 100 Times in 51 Posts
I agree about the polarity of the crank trigger wires. I've seen it and fixed it before.
Dan
voltdr is offline   Reply With Quote
Old 09-25-2015, 02:24 PM   #4
GaryGoFast
I think that box has to have "0" degree retard chips when no retard being used.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 09-25-2015, 04:26 PM   #5
buzzinhalfdozen
Liked 11 Times in 8 Posts
YEP, had a freind 2 weeks ago was about to load up after trying everything he had, motor just didn't sound right either. So I asked him what have you done...he said nothing just pulled this chip out cause I didn't need it, he put it in FIXED. Those units require a chip in each position always.
Joe Buchanan SS/BX 3117
Old 09-25-2015, 10:54 PM   #6
flash
Liked 6 Times in 5 Posts
I have 0 retard chips in each retard slot.even took them out and put 4 more new ones in!
flash is offline   Reply With Quote
Old 09-26-2015, 05:57 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
All 4 retard inputs must also be grounded besides having the zero pill in if the retard is not being used.
I'd check that ground .
Old 09-28-2015, 10:20 AM   #8
Bobby Fazio
Bobby Fazio's Avatar
I had the same problem. Take these chips out and do a OHM test with a multimeter. They should have 0.00 ohms. Regardless, if not using high speed timing control, throw these chips away altogether and ground the Timing #1, #2, #3, #4 terminals on the side of the box. Daisy chain three of the them and then run to a good ground. I had this same problem.
'65 Mustang SS/L & L/SA
