Liked 333 Times in 180 Posts
Check timing belt/gear/chain first---as you rev up the engine the stretch tends to retard the timing---next any MSD system needs to be wired this way or gremlins can present themselves
all Wiring MUST BE STRANDED wiring at least #12 preferably #10 at the least #4 starter wire--prefer #2 or #0 same for ground ground heads to block ground block to frame ground MSD directly to the battery |
