Old 09-09-2015, 01:07 PM   #1
Liked 10,652 Times in 2,210 Posts
Default Death Of A Block
Pulling my old backyardgin engine apart for the last time made me think of all the good things we have done. Block is broke and not repairable, its racing days are over. Maybe it will come back as a cast iron skillet and cook many a great meal. It could come back as ornamental iron used on Bourbon street and catch beads and watch the constant party.
We only missed one Indy and that was my fault. I have no idea how many rounds you help me win after I did a poor job one the line and you run right on the number.
Bottom line you taught me a lot after I learned to listen to what you were trying to tell me.
Old 09-09-2015, 04:52 PM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Death Of A Block
Larry, something that gave you that much service needs a good final resting place. Check out this website for some great ideas on coffee tables made from blocks. -Al
http://www.theparksideonline.com/the...k-coffee-table
"That'll never work....."
Old 09-10-2015, 08:54 AM   #3
Billy Nees
Liked 7,636 Times in 1,724 Posts
Ain't it funny how that works? Really good blocks DO go to Heaven just like the Goldfish we had when we were children.
Billy Nees 1188 STK, SS
I'm OK..........it's everybody else.
Old 09-10-2015, 09:03 AM   #4
Greg Reimer 7376
Liked 698 Times in 216 Posts
Cool Re: Death Of A Block
If that's a 440 block, you wouldn't have to worry about someone stealing it and carting it out the door.
Old 09-10-2015, 09:46 AM   #5
Paul Precht
Paul Precht's Avatar
Liked 307 Times in 116 Posts
Hi Larry, could you put up a pic of the block damage, the only 440 block I've seen broken was a friends who ran twin turbos on Alcohol with about 35lbs boost in his drag boat.
Old 09-10-2015, 10:16 AM   #6
modelman1960
Liked 55 Times in 22 Posts
Larry & Patsy, Was so sad to hear of your problems at Indy through the "live" reports. Here's an idea for the block that will allow it to continue to serve you in another capacity. It may not be necessary in your locale, but up here in C.N.Y. this works really great. A drag racer that lives about 5 miles from me got tired of the snow plows taking down his mail box every winter, so he built a base from an old B.B. (broken) Chevy Block, then welded a crankshaft to the block, put his mail box on the end of the crankshaft, then surrounded the mail box with an old dragster style roll cage. He painted it orange, and the plows haven't taken it down since.
Re-purpose and re-use Sir.
Does this mean you're done racing for the year?
That would be even sadder.
Walt
Old 09-10-2015, 07:39 PM   #7
Trying to get another bullet ready.
Old 09-11-2015, 04:02 PM   #8
Andrew Hill
Andrew Hill's Avatar
Liked 170 Times in 38 Posts
Ever seen top gear? Turn that block into a coffee table!
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 09-12-2015, 10:35 AM   #9
Jim Cimarolli
Liked 166 Times in 46 Posts
Talking Re: Death Of A Block
I don't think Patsy would go for that!
Jim Cimarolli is offline   Reply With Quote
Old 09-13-2015, 11:31 AM   #10
The block will become a cam break in tool. Turn the mains upside down, oil pump, drive gear, oil pan, heads, rockers, front cover with hole, and 1/2'' drill. I only do four cylinders at a time in a skip one order. 1, 4, 6, 7 or 8, 3, 5, 2.
Paul the block split between 4 and 6 at its thinnest part in line with the crankshaft centerline , the block had 8 sleeves in it
