Old 11-20-2007, 12:55 PM   #1
Ty Webb
Default Re: Index Changes
They were considering lowering the SS indexes to keep the Stockers out of SS. Was this due to SS'ers crying about the Stockers?
Ty Webb is offline   Reply With Quote
Old 11-20-2007, 01:12 PM   #2
Jeff Lee
Jeff Lee's Avatar
I think it would be great if dedicated Superstockers weren't bumped out of their own class by traveling pro's with their stockers because they are bumped out of their own class as a result of NHRA eliminating their own category for that particular event. More so if NHRA cuts to 64 car fields as a maximum for any / all events once the pro side of NHRA takes affect.
Jeff Lee 7494 D/S '70 AMX
Old 11-20-2007, 02:07 PM   #3
Tony Janes
Jeff how many traveling pros are there? That is a non issue. 64 car field, that is not going to happen either. If stock and super stock is going to get cut for a time basis, it will in the number of time trials.
Tony Janes 7941 STK, SS
Old 11-20-2007, 02:42 PM   #4
Speedracer
Smile Re: Index Changes
I think you are right about the 64 car fields.Thats not going to happen.32 might be more like it.
Speedracer is offline   Reply With Quote
Old 11-20-2007, 02:57 PM   #5
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
NHRA will still need the filler
Old 11-20-2007, 03:31 PM   #6
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
The new filler is already in the experimental stages at Divisionals. T/S & T/D. Or if you race at the Pomona events it is called Super Pro & Pro, I believe.
But do not worry, soon you will only be at Sportsnationals.
Be thankful that they do not use lie detectors instead of Tech, the fields would then be down to 16, at -.40 under.
See, people complain, and NHRA has responded.
Ron Ortiz
U/SA
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 11-20-2007, 03:34 PM   #7
Jeff Lee
Jeff Lee's Avatar
It looks like anywhere from 3-5%. Your right, it should be a non-issue. It should be so insignificant that NHRA makes absolutely no concession to such a small group. NHRA should, as a business or community of racers, should not yield one iotta to such a small faction and should make every effort to appease the majority. Isn't that the way it is?
And I sure hope your wrong about the number of qualifying runs! Because your talking about going down to 1 in some instances!
Old 11-20-2007, 03:48 PM   #8
Speedracer
There certainly is not a lack of potential filler.Top Sportsman,Top Dragster,Top Super Stock,Top Stock,Top Snowmobile,Top Motorhome.Top Pit Bike.The list could go on and on.
Old 11-27-2019, 12:16 PM   #9
Jim Caughlin
Liked 805 Times in 245 Posts
I've seen some of those Top Motorhomes is secret testing, they do some pretty impressive wheelstands...
Jim Caughlin is offline   Reply With Quote
Old 11-27-2019, 05:46 PM   #10
Terry Friar
Liked 16 Times in 2 Posts
Secret testing of motorhomes?? That tells where they came up with the term "Super C"!
Terry Friar is offline   Reply With Quote
