Old 08-04-2015, 11:33 AM   #15
dhofer
Default Re: Ss/x
Originally Posted by 1720 View Post
“As far as who the "hitters" were in SS/X...Kronenbitter would be top spot with the "Bits-n-Pieces car.”
“Vacuum leaks were hard to stop back in those days on those Rochester 2 barrels”
These thread comments have brought back many memories. My brother and I ran SS/X in a '60 Chevy, 283/3 speed stick in the '72 season, attending the 72 Indy Nationals only to get "caught up" in vacuum leak deal. The Bits-N-Pieces car was pitted near us and offered a couple shifter side plate linkages after breaking. http://talbotracingteam.wink.ws/indy%20letter.htm
We never did qualify, but it was an experience that turned us to Brackets the next season!
Ralph T.
Ralph
We also attended Indy 72. Our SS/W car was also "caught up" in the "carb leaking" mess and we also didn't qualify. We did have the fastest "W" car there but got beat on a hole shot. Given a heads up on the rule change I know we could have gotten to the record with a cam and gear change. I remember your letter to the editor well since all the cars had to run on the records and they were all set the same way. You did a great job of expressing the frustration of all the "X & W" competitors that made the trip to Indy and were blindsided by the rule change. In "W" we weren't in as bad of shape since the min. was never broken but still a hard number to hit.
Originally we just didn't tighten the carb down tight and that worked pretty well. Later we tried different things. The car ran best when we drilled and tapped the underside of each intake runner in the intake manifold and installed a carb. jet I can't remember what size but the air came from the breather tube at the back on the motor, the carb jetting was adjusted accordingly to match the increased air flow. In any case the motor really responded to this and the car flew.
Dave
dhofer is offline   Reply With Quote
