Old 07-31-2015, 11:59 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Look before you pull out
You also need to look back when leaving the ticket booth/scales.
Rich Taylor
I/SA - 321
Old 08-02-2015, 03:32 PM   #2
Shake & Bake
Liked 37 Times in 33 Posts
Maverick,
You are correct. Two drivers did bump into one another on the return road during S/G time trials. It was Gary Linkhorn and Tim Tiry. The car that Tim had just ran pulled the chute (Big mph car) and pulled over on top of the hill (across from the safety crew) to gather the laundry up. Gary and another racer was down the hill pulled over to the right. Tim went by the guy that pulled over on top of the hill at that time Gary was starting to pull out. I guess Tim didn't see Gary due to the height of the hood scoop. They did bump into each other. They both pulled over to the right, stopped and got out. Gary was able to make the call for first round, don't know if Tim was able to make it.
Shake & Bake is offline   Reply With Quote
