Liked 279 Times in 68 Posts
There is no way those parts cost 15,000 for a small block Chevy. The block is around $1300, the rods about $600, pistons and rings $1200, roller rockers $300, don't know about tool steel lifters, we run Smith lifters which are around $700. That adds up to $3700 before the heads and intake. Let's allow $4300 for the heads and intake from Top Notch. Looks like 8k to me. I realize it takes more parts than that, cam, bearings, gaskets, oil pump, and assorted others. I bet you I could get an good engine builder I happen to know well to build a 1.10 under 305 for 12k with some really good stuff and would go right through tear down.
Greg Hill 4171 STK |
#2 | |
Liked 269 Times in 99 Posts
Banned
Liked 5 Times in 3 Posts
Not gonna get in a pissing match on here but here's the break down on parts cost:
Dart block all done, bored, honed, lifter bushed and race ready is $2500 Top notch heads and intake with valves, springs, head studs and guide plates $5000 Tool steel lifters top notch dlc coated from trend $1100 Roller rockers from comp, ultra pro magnum $500+ Metric ring set with ring spacers (best stuff) $1375 Manley pro I beam rods $1175 Cp stocker pistons $800-1000 Good crank is gonna run you $1000 And you still haven't bought pushrods, gaskets, timing set, bearings, timing cover, oil pan, carb, and all the little accesories. I build these for a living and buy the parts on a daily basis so I kinda know what it costs...and I also can gurantee mine will go "right through tear down" also... Last edited by Allen Sherman; 07-11-2015 at 06:29 PM. |
