Old 06-17-2015, 02:37 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: motorhome gas guage
Bill, then the sender you're using is set up backwards, the resistance empty to full is reversed switching the wires won't help (as you know now) . Most systems I work on (GM) use 250 ohms for an empty reading and 40 ohms for a full reading. Maybe see if the supplier you used has a similar unit with the resistance values reversed. I'm unaware of a way to correct the unit you have, without "flipping the card" basically taking the resistance grid and flipping it upside down so you get the needed values. Good luck. Joe
Joe Buchanan SS/BX 3117
