Old 05-15-2015, 11:55 AM   #29
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: 1965 Impala BBC Stocker Update
Where car is at today.
1) Fuel Cell/Pump / Battery installed. Just got rest of braided line to go up front. When I last used this fuel cell I have a AN Fitting plug for the unused outlet but it would drip leak. Any suggestions to seal including sealants?
2) Ignition mounted on the dash side of heater core block off plate. Battery cable runs up to a lug on this plate then a separate cable to starter. Battery cable #1 welding cable.
3) Front suspension with QA1 Adjustable shocks. Right now set on the "80/20" setting. Six cylinder springs with 1.5 coil cut out. Stock disc brake conversion. Lighter drag race version part of the "later upgrade" list. Master Cylinder from 83 Dodge.
4) Engine compartment. Basically waiting for the 396!
ID:	28499   Click image for larger version
ID:	28500   Click image for larger version
