Old 05-11-2015, 11:26 AM   #1
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Ford vs Chevy Build-up
Call Dynamic. Band adjustment, maybe?
SSGT Mustang is offline   Reply With Quote
Old 05-11-2015, 08:03 PM   #2
fordteacherguy
Liked 160 Times in 51 Posts
C-4 output shaft turning effort higher in one direction than the other is normal.. there is less turning effort when the rear one way roller is overrunning..... higher effort when the rollers are holding and the gear sets are turning.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 05-11-2015, 09:01 PM   #3
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
The AODE that I re-built acted the same way. good job so far Rich.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 05-12-2015, 12:09 AM   #4
fordteacherguy
Rich,
Lean that tune up to around 13-13.2 and watch it pick up a ton!
Brian Thompson
Old 05-12-2015, 01:15 AM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Originally Posted by fordteacherguy View Post
Rich,
Brian - The second pass (handed off to Kenny) he reported 14.0ish before he crossed the stripe. I did not have the camera in the car that pass and took him at his word...was afraid to lean it any further at that juncture. I'm pretty sure it's still a sour air/fuel ratio problem which I will have to get a handle on.
After Alan brought up the drive shaft phasing I began to doubt myself and took a look at it again today...all looks good as far as I can tell. I'll re-check pinion angles again. Car is on a lift with the rear fully extended in the pics, thus the extreme angle at the pinion.
Junk shots under the car...
Had some popping going on at cold start initially...figured it was lean at idle and WB confirmed. Gave it a little more fuel at that point and calmed it down. I'm wondering if I should just remove the piggyback for now and let the wideband O2 sensor tell me what to do via fuel pressure adjustment.
Rich Taylor
I/SA - 321
Old 05-12-2015, 06:23 AM   #6
SSGT Mustang
Is it an illusion, or has the u-joint moved? It looks like it's not fully seated to the end of the bore on that yoke (bottom bore in this picture).
Old 05-12-2015, 07:12 AM   #7
HandOverFist
I'll look at it close today, but if you view the rear it has about the same appearance.
Edit : U-joints are fine.
Rich Taylor
I/SA - 321
