Old 04-16-2015, 12:51 PM   #1
Bryan Worner
Liked 535 Times in 86 Posts
Default Re: NHRA and AHFS
I never actually read the whole mine shaft rule, but you would think mineshaft is mineshaft and no runs would get penalized! What does mineshaft mean for Comp? Can they still get a permanent hit if it's mineshaft for them?
Bryan Worner is offline   Reply With Quote
Old 04-16-2015, 02:52 PM   #2
Liked 10,902 Times in 2,255 Posts
1.33 under during qualifying at the Jegs Allstar no AHFS!
If the racer uses the 1.33 under qualifying time to get on the sheet for either Stock or Super Stock eliminator at that same national event the AHFS will apply. That seems fair.
If that scenario works for the All Stars, why does this not apply to the Factory Showdown cars?
Let the Showdown put on the good show without AHFS, but when they use that same qualifying time to place themselves on the qualifying sheet for the eliminator let the AHFS apply.
Old 04-16-2015, 03:24 PM   #3
Nick Heath
Liked 576 Times in 137 Posts
Comp cars can still get a permanent CIC in mineshaft conditions, but the trigger moves from -0.61 to -0.66. So a -0.66 run will be a .01 permanent hit, -0.67 will be a .02 hit, and so on.
Old 04-16-2015, 03:41 PM   #4
Jeff Stout
Liked 706 Times in 283 Posts
This sounds like a much easier and better idea. If mineshaft conditions exist then raise the hit. EX: 1.05 instead of 1.00 1.25 instead of 1.20 Or whatever increase seems reasonable. Then let AHFS does its job.
To me if your running that fast in any condition mineshaft or not don't you think motor should get HP with any combo? I do. It must have been a soft combo that was protected and potential was shown.
Im speaking in general and not finger pointing any 1 particular combo
Old 04-16-2015, 04:05 PM   #5
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Bryan, Comp racers get a 'nickel' extra to play with. If the first car in the bottom half of the field in qualifying (#17 in a 32 car field) is -.61 or more under, the mark for a permanent hit goes from -.610 to -.660. Maybe S/SS could get something similar (i.e. -1.25 or -1.30 for an automatic hit).
