Old 04-09-2015, 02:13 PM   #1
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default Re: '66 Malibu N/SA
Hey Dave, glad to see you finally getting to work on the Malibu. Did you sell the Camaro?
Old 04-09-2015, 02:33 PM   #2
Okay, here they are..Look better?
I've still got to fit the split guide plates later on.
See Kadar Performance, LLC on F/B
ID:	28101   Click image for larger version
ID:	28102   Click image for larger version
Old 04-09-2015, 02:38 PM   #3
Here's the carb, which was a swap meet special, now with lots of new parts from Larry Fulton.
Not a 100 pt. restoration but I think it looks alright.
Old 04-09-2015, 02:41 PM   #4
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
It does look great. Is that a flare fitting on the front?
Dave Muller is offline   Reply With Quote
Old 04-09-2015, 02:56 PM   #5
Yeah , It's just a 3/8 flare fitting I stuck in there.
I think that's enough line from the regulator.
Bigger is not always better if it loses speed of delivery.
Old 04-18-2015, 07:55 PM   #6
Dave Muller
Lest anyone think there's been no progress at all lately, here are a few new pictures.
Here the fuel cell is in.
Here's the underside, with the fuel pump and filter. The main fuel line is installed, but it's clear that I need a 90 degree AN fitting to run to the fuel cell, so that will be a few more days before that's done.
Next I'll be putting the axles in and checking tire clearance prior to buying the wheels and tires for the back.
Old 04-26-2015, 07:25 PM   #7
Dave Muller
I'm inching along a little further, the vent tube is ready once I get the correct fitting, and the line from the fuel cell is in. I will trim off the vent tube so that about 1/2" protrudes, then the four bolts hanging there will attach straps that capture a rectangular piece of foam to protect the vent from any debris going in. Probably overkill, but I prefer it that way.
I also measured for tire clearance. It looks to me like either 5" or 5.5" backspacing would work for a 10" wheel (assuming a 9 x 30 tire), but I think 5" will center the tire better. On the other hand if I start with 5.5" backspace I can always use spacers to adjust. So I'm still on the fence a bit there.
I tried installing the rear sway bar, it's a 1" bar of the general sort the factory used. It's a UMI Performance piece, same company as made the control arms I'm using. But it doesn't seem to quite fit, it appears to be about 5/16" too wide. I'm leaning towards just returning it and getting the H and R Parts sway bar. It's more expensive (that's why I originally went with the stock type) but it should circumvent the current problem, and it sounds like they work better anyway.
Old 03-15-2016, 11:53 PM   #8
Dickens
Liked 12 Times in 8 Posts
Very Nice work.........great combination
Dickens is offline   Reply With Quote
Old 03-19-2016, 02:57 PM   #9
Dave Muller
Loaded up the car on the trailer this morning so I can take it into a shop for suspension work on Monday. Bushings, ball joints and the Santhuff springs are all in the cab. This is also the first time that I've used this winch. Worked out pretty well for something I bought for little more than loose change at Harbor Freight. I'm doubtful if it'll last but we'll see.
Here I am posing with the car:
And here's my son posing by it trying to make it look like he's the one that did all the work:
Old 05-31-2015, 07:59 PM   #10
