Old 04-04-2015, 09:49 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Any Greenies in the audience?
An Inverter produces AC from DC and a Converter produces DC from AC. A generator produces AC and is your primary power source. Your battery powers your inverter. An Inverter style generator is just a different way to make AC using an engine for power. Sounds confusing but really isn't. Cheap generators no matter who's name is on it are Made in China. Honda is the std all others are judged by.
Rich Biebel
S/C 1479
Stock 147R
Old 04-04-2015, 10:44 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Well satisfied with the Yamaha 2000. I think it and the Honda equivalent are nearly identical in performance and features. You can join two of these together for 4000 watts if desired. They are so quiet I'm constantly checking to see if it is even running.
Rich Taylor
I/SA - 321
Old 04-05-2015, 07:01 AM   #3
Rich Biebel
Yes those Yamaha generators are very good and quiet.
Rich Biebel
S/C 1479
Stock 147R
Old 04-05-2015, 07:39 AM   #4
SGSST109E
Liked 126 Times in 61 Posts
I have solar panels on the top of my trailer for the last 16 years. They keep the batteries charged for the winch and power for the laptop, weather station, radio etc. I have a Honda 3000 which is great but I rarely have to use it. Solar panels are very cheap now between $1.00 to $1.50 a watt.
SGSST109E is offline   Reply With Quote
Old 04-05-2015, 10:02 AM   #5
Greg Gay
Liked 286 Times in 73 Posts
Thank you for the responses, everyone. Very informative. I will probably go with the inverter/generator, but SGSST109E: How do you control for the variable input of the solar panels?
Greg
Greg Gay is offline   Reply With Quote
Old 04-05-2015, 10:13 AM   #6
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
check out with Bill Bagley, he races and sells Honda Generators at great prices, will ship to your house, tell him Nitro Joe sent you.
Bagley Tractor
& Equipment
3709 South Eastman Road
Longview, TX. 75602
800-281-0256
903-753-8262
903-753-3651 Fax
http://www.bagleytractor.com/
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
Old 04-05-2015, 11:05 AM   #7
rognelson777
Liked 135 Times in 74 Posts
Correct me if I am wrong but my understanding is portable Inverter style generators are the quiet units.
I also think Honda now makes economy units and they are not quiet.
To me, noise is the issue, I also learned because it says Honda on it does not mean it is a good unit, I learned this with a honda black max lawn mower I bought, what a mistake. Do your research
rognelson777 is offline   Reply With Quote
Old 04-05-2015, 04:40 PM   #8
Rich Biebel
Inverter-Generators are quiet and built from the ground up to be.
Industrial units are not quiet. Very little covering the engines on those.
DB ratings for Inverters are usually 50-60 and Industrial units are usually in the 70's
A big difference there noise wise....
I don't sell Honda equipment but their reputation is number 1 in the small engine power equipment world....I am sure they have failures too...
Rich Biebel
S/C 1479
Stock 147R
Old 04-05-2015, 10:36 PM   #9
SGSST109E
The device is called a charger controller. The three batteries in the trailer never have to be charged. I use a older technology one, the newer ones uses more of the panels power. If you are using a higher voltage panel it very important. Mine put out 45 volts in peak light. If you use panels that put out around 18 volts it is much easier to control. The industry has come a long way in the last 15 years. I have almost 900 watts on my trailer. So I can keep the batteries peaked, run the laptop and weather station, pager and radio. Can also run a fan all on solar. All weekend long. Then I put the battery charger on the race car battery over night off the batteries. One of these days I will put a small panel just to maintain the race car battery with it own charge controller.
Old 04-05-2015, 10:39 PM   #10
SGSST109E
As Rich says the Honda's are great. My 3000 can be running in between you and I and we can have a conversation like it wasn't even there. I think on econo mode it 50db
