Liked 32 Times in 19 Posts
always impressed that many open minded people realize it might be better to get away from Third Handed HP ratings and easily manipulated AHFS and use Cubic Inchs for a Basic class.
THe econo Modified discussion in earlier posts indicated how to limit costs. No computer for eliminations, any flat top piston, Spec Brodix heads, Spec carb, Lb/cubic inch any SS chassis with any rods, any crank, No external vacuum, no external oil pump. Hole in pan to police. Stock placement of Dist. Spec spring and Cam size. Might even give wt break for regular chassis versus FWD chassis of 50#. Take off headers to check heads, tech Carb, Check wt, and look in pan.Pump. Easy tech. |
Liked 61 Times in 25 Posts
Here is a rule set that is already in place and working, so there are already cars to draw from. There is also a similar class for the Ford guys. Pick a crate engine for the Mopar guys, and then you have a HEADS UP class with the 3 major brands, and tear downs become a non-issue. Also eliminates the costs associated with experimenting with cams, valve jobs, ring packs, etc, etc, etc. Lots of cars that are gathering dust could easily be pulled out of retirement, and with an engine swap, be racing. Rules could easily be adjusted to include SS type cars also, because at this hp level, there is no real advantage chassis wise.
While the NMRA and NMCA are fine small scale sanctioning bodies, I think a class like this would be a major deal if ran at NHRA/IHRA. http://www.google.com/url?sa=t&rct=j...89381419,d.eXY Last edited by Tony Corley; 03-30-2015 at 09:22 AM. |
Liked 3 Times in 1 Post
something is coming
Liked 172 Times in 46 Posts
With the improvments seen in converter techknowledgy and what is being done with transmissions. I do not belive that automatics should get the weight break. Today a pretty even deal, in my opinion.
Dirk
Dirk Olson 5036 STK |
I don't know that I agree with that, especially on a lower hp deal. The auto still robs more hp than a stick.
Liked 20 Times in 15 Posts
How about a combo that lets you run NHRA/IHRA and NMRA. With a tire change you could be racing anywhere and anytime. Builds the sport. Gives older cars an opportunity to run. Win Win.
I thought that's what I proposed above? Granted, there is not a place for the older engines, but the older cars can race. Problem with older style engines is that it is going to be impossible to get the factory involvement the new engines have. Plus, if you don't do a sealed engine, sealed tune, (once again, much easier to do and monitor with computer), then you start back getting into the "trick of the week" club, where lots of money is spent testing and trying new parts. Pretty soon, the low dollar guy gives up on a "heads up class", and goes back to bracket racing.
The only reason I can think of that someone would bracket race over heads up racing is that they don't have either the time, know how, commitment, or money it takes to field a competitive heads up car, (or any combo of the above). The classes I proposed eliminates the majority of excuses. |
Liked 319 Times in 68 Posts
Professor Dave hit the nail right on the head.
Lee Valentine 1661 STK |
Which post was that?
