Old 03-17-2015, 07:38 AM   #2
Robbie Welch
Liked 262 Times in 124 Posts
Default Re: Shifter not shifting
60 lbs sounds low, I run 90lbs and I know people that run120lbs. I use a trubo action shift on a 3 speed trans. Also you should be able to test the air shifter without running the car. I hope this helps
