Old 03-11-2015, 09:29 PM   #1
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
Thanks Al, and Richard! RIchard, Your Camaro looks mighty fine, too... Hope you have some fun with it, and get that 327 back in there soon... Anxious to see how much you improve, over last year... My engine will come out Saturday... and i will hopefully have cam in and degreed by Sunday, and putting head back on... just waiting on lifters, from coating in Chicago, then i can finish it up...and an order to Jegs, for some break in oil and cam assy lube. If i can pick anything up, we'd probably be a good heads up race!
Old 03-12-2015, 12:55 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You should bring your car to Bowling Green in June for the Hot Rod Reunion Brent...you would have a blast.
Rich Taylor
I/SA - 321
Old 03-12-2015, 09:49 PM   #3
brent flynn
It would be fun.... but, if i dont get all the stuff done, it wont be goin anywhere...hehe...
Im curious how your cable for your shifter is routed... ive got a Hurst in the car, now, but goin to a Cheetah sometime soon... i got a great deal on a used one... is it routed where you can see it, to take a pic, from inside the car?
Old 03-13-2015, 01:05 AM   #4
HandOverFist
Just so happens I have the shifter loose atm to replace the neutral safety switch...I'll snap a pic of it this weekend for you.
Rich Taylor
I/SA - 321
Old 03-16-2015, 09:50 PM   #5
brent flynn
Awesome~ !
Ive just about got my engine ready to go back in... pulled it Saturday...removed driver side head, installed new cam and degreed it yesterday...lifters should be here by Thurs, then i can finish it...
Old 03-24-2015, 10:45 PM   #6
brent flynn
In case anyone is wondering... I fired the car on Saturday...put 45 mins on it... retorqued the heads tonight, intake and headers too... thought id start replacing valvesprings...did 1 and 3 cylinders, just to get warmed up...will finish spring swap tomorrow eve, and set valves... just waiting on sunny and 65*
Old 03-25-2015, 01:07 AM   #7
HandOverFist
Going to be sunny and 49 degrees at Bowling Green this Saturday. Not sure I want to even try here.
Rich Taylor
I/SA - 321
