Old 11-05-2007, 08:21 PM   #1
SSDiv6
Default Re: 283 head gasket???
Originally Posted by JRyan View Post
Use the gasket that was made for a 283, Stock GM #3995633. They are slightly smaller in the bore and usually measure around .021". I just bought some late this summer, so they are still available.
Jerry
Jerry is correct regarding the bore size. I have a set for sale if you need them. Send me a PM if interested.
Old 11-05-2007, 09:17 PM   #2
james schaechter
Liked 1,436 Times in 299 Posts
Cometic makes any bore size. I use them on our 283 stocker.
James Schaechter 3163 STK
Old 11-05-2007, 10:53 PM   #3
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
3995633 is the gasket to use, Jerry correct me here but I think that gasket is for a 307. But
they are still available and can be stacked if needed without any problem. I remember the
last batch that I bought being .017 but that was several years ago.
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 11-06-2007, 12:34 AM   #4
Dennis Paz
Liked 5 Times in 3 Posts
Thanks for the help, I figured someone would have the correct part number for the small bore gasket.
Anyone have a good pan for a chevelle? GOOD!
Dennis Paz is offline   Reply With Quote
Old 11-07-2007, 02:15 AM   #5
JRyan
Liked 112 Times in 31 Posts
Hi Joe,
Been awhile. You're right. The 3995633 has been listed as the 307 (Chev) gasket for years. I've had them as thin as .016" metal thickness, but they always check at around .020 - 021" in the bead area after they've been compressed. You're also right about the stacking Joe. We went to aluminum rods in a Super Mod years ago with 14.5 to Compression. Of course we needed the extra clearance, and nobody made a race gasket at the time, so we took the advice from Da Grump himself and stacked them. Very fast car for it's day, and never a problem.
Jerry
